Hi people!
We bought a FIT-PC2 and I am having issues by using USB Wireless Adapters. Those two adapters I tried to use with are TP-LINK, TL-WN723N and another from CONRAD Stick N 300 mini. With the TP-LINK adapter (drivers are installed correctly) I get the message this device is unknown not identified. The CONRAD adapter does a bit better you can use for a while then it has malfunctions in functioning. After 5 minutes it is not able to search for networks and connect. I also noticed that when I plugged into the USB ports on the back side it didn't work at all. I got some result when I was trying the mini USBs on the front. Anyone ever experienced these kind of problems? Any solution or product that works? We didn't order FIT-PC2 with built in Wi-Fi because our costumer wanted in this way.
Thanks!
External USB Wi-Fi adapters problem
Post by lolhun1988 »
Wikipedia is our mother, Google is our father!
