XP Drivers
Posted: Mon Apr 20, 2009 6:44 pm
by RISC
I have to install German XP-Home SP3 for Test purposes. Can you let me have all required drivers to be loaded after basic installation. Thanks in advanve
Re: XP Drivers
Posted: Fri Apr 24, 2009 12:51 am
by airwave
I have the same problem - need to install XP Pro and need the drivers for this. Does anyone have a idea where to get them?
Re: XP Drivers
Posted: Fri Apr 24, 2009 6:38 pm
We will prepare a set of custom XP drivers shortly.
Re: XP Drivers
Posted: Sun Apr 26, 2009 11:52 am
Re: XP Drivers
Posted: Thu May 14, 2009 5:41 pm
by mrrrk
Hi
Have just installed XP Media Center and thought I'd share my experiences. If you install the chipset drivers, all USB ports will stop working so get the hotfix from here first:
http://support.microsoft.com/kb/921411
(without this, the chipset drivers turn your PC into a paperweight since you can't use the mouse or the keyboard!)
I managed to get the driver for the IR port (igorplugusb.zip) from here:
http://www.avrfreaks.net/index.php?modu ... showinfo=1
Cheers...
Re: XP Drivers
Posted: Sat May 16, 2009 7:56 am
by sol radiation
hello. i was researching this small pc to possibly use as a low powered HTPC in a bed room and saw u installed xp media center......is it working ok? how is high def 1080p playback over a netwok and how are u handling the audio? any feedback would be helpful. thanks
