How to enable the microphone to work
Polo
Post by Polo »
The speaker is OK.
But the microphone does not to work, when I try to record something by sound recorder.
Also same applications, such as Skype, I can hear from my friend, but my friend can hear from me.
I checked that the Microphone is not in mute, and also its output level is not zero.
I also removed the pulseaudio and used the alsaaudio, but the result is the same.
If anyone knows somethings, please give me advise.
Denis
Re: How to enable the microphone to work
Post by Denis »
Seems MIC is still muted somewhere.
Right click on Sound Preferences -> Open Volume Control -> Recording -> Capture must be unmuted too. In any case I attached config file with all settings, put it instead your /var/lib/alsa/asound.state, reboot and try to record.
state.MID {
	control.1 {
		comment.access 'read write'
		comment.type INTEGER
		comment.count 2
		comment.range '0 - 64'
		iface MIXER
		name 'Front Playback Volume'
		value.0 64
		value.1 64
	control.2 {
		comment.type BOOLEAN
		comment.count 2
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
	control.3 {
		comment.count 2
		comment.range '0 - 65'
		iface MIXER
		name 'Mic Playback Volume'
		value.0 44
		value.1 44
	control.4 {
		comment.count 2
		iface MIXER
		name 'Mic Playback Switch'
		value.0 true
		value.1 true
	control.5 {
		comment.count 2
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
	control.6 {
		comment.count 2
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
	control.7 {
		comment.count 2
		comment.range '0 - 35'
		iface MIXER
		name 'Capture Volume'
		value.0 3
		value.1 3
	control.8 {
		comment.count 2
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
	control.9 {
		comment.count 2
		iface MIXER
		index 1
		value.0 0
		value.1 0
	control.10 {
		comment.count 2
		iface MIXER
		index 1
		value.0 true
		value.1 true
	control.11 {
		comment.type ENUMERATED
		comment.count 1
		comment.item.0 Mic
		comment.item.1 Line
		iface MIXER
		name 'Input Source'
		value Mic
	control.12 {
		comment.count 1
		comment.item.0 Mic
		comment.item.1 Line
		iface MIXER
		name 'Input Source'
		index 1
		value Mic
	control.13 {
		comment.count 1
		iface MIXER
		name 'Master Playback Volume'
		value 64
	control.14 {
		comment.count 1
		iface MIXER
		name 'Master Playback Switch'
		value true
	control.15 {
		comment.access 'read write user'
		comment.count 2
		comment.range '0 - 255'
		comment.tlv '0000000100000008ffffec1400000014'
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
	control.16 {
		comment.count 2
		comment.range '0 - 120'
		comment.tlv '0000000100000008fffff44800000032'
		iface MIXER
		name 'Digital Capture Volume'
		value.0 60
		value.1 60
Polo
Post by Polo »
Mr Denis, thanks for your rapid reply.
I changed the config file asound.state according to that you give to me. It works!
Thank you again.
Return to “Ubuntu 8.04”
