Hi all,
PPA for fit-PC2 available at https://launchpad.net/~fitpc2/+archive/ppa/
Re: PPA for fit-PC2 available
Thats awesome... any idea when you will have support for intrepid?
Tim
Tim
Is it possible for you to put the right package to run 3d acceleration on this repository?
And why not uploading on this repository all the package (for example the most performant kernel/drivers that could run) that the fit-pc 2 need to run perfectly on .deb based linux distribution (ubuntu) ?
Thank
Thank
Would it be possible to get the .config (from 'make config') file that is used? I didn't see it in linux-source-2.6.24_2.6.24-34.7~1fitpc2_all.deb.
Are there any plans to compile against any of the 9.x series at this stage?
Also, is it possible to post a link to the different sources you are using?
