No network on first startup?
tsuki_chama
Post by tsuki_chama »
I just received my fit-PC2 (Linux version), and when I first started up, networking wasn't working. NetworkManager didn't run, and trying to get into network-admin (System -> Administration -> Network in GNOME) came up with a permission error, even when I ran it as root.
Luckily, an update seemed to fix the problem - but you need an internet connection to update! Here's how, if anyone's stuck with this problem:
Open up a terminal (Applications -> Terminal)
We'll need to do all this as root, so enter:
su
and enter the password "111111" when prompted.
Then enter the following commands, replacing <yourIP> with a valid IP on your local network, and <routerIP> with your router's IP (I used 192.168.1.100 and 192.168.1.1 respectively, but your setup may be different):
ipconfig eth0 <yourIP> up
route add default gw <routerIP>
apt-get update
apt-get upgrade
You'll get a bunch of warnings about the Medibuntu repository not having a valid signature when you run apt-get update - these can be ignored.
Mirco
Re: No network on first startup?
Post by Mirco »
Hi sorry if is ot, but where have you buy fit pc2?
tsuki_chama
Mirco wrote:Hi sorry if is ot, but where have you buy fit pc2?
www.fit-pc.co.uk
Might be out of luck if you're not in the UK though...
Return to “Ubuntu 8.04”
