Remote Control Support
tsuki_chama
Post by tsuki_chama »
Just checking, is the infra-red port on the fit-PC2 supported by default on Ubuntu 8.04, or are additional drivers required? Should it work normally with LIRC?
Re: Remote Control Support
IR is not supported yet in Linux, only in Windows. We are working on Linux support.
tisoft_media
Post by tisoft_media »
Can you say what kind of inrared port that is? like how is it connected, what chip...
prj
Post by prj »
The driver is named avr309 so that is a good hint.
Take a look at http://www.atmel.com/dyn/resources/prod ... oc2556.pdf
So it's a small AVR microcontroller with a firmware that converts serial RS232 to USB. Hence the IR device should be visible when doing lsusb.
I've found references to IgorPlug inside the windows driver so that is the firmware we're dealing with.
tisoft_media
I have it working under ubuntu :)
Will post the solution, but i am on the run right now, so will do it later.
teetee1
Post by teetee1 »
tisoft_media wrote:I have it working under ubuntu :)
Please do. I am also working on getting Logitech harmony 880 remote control working for this box by using concordance and congruity but the driver installation was tricky for me.
tisoft_media
I have uploaded an updated lirc-module-sources here:
https://launchpad.net/%7Emarkus-tisoft/+archive/fit-pc2
Return to “Ubuntu 8.04”
