Ubuntu recovery image now available
fit-PC2 Ubuntu recovery image is now available at http://fit-pc2.com/download/ubuntu/releases/
Re: Ubuntu recovery image now available
Awesome thanks.
Unfortunately
I am getting not found for the image. (However the sums are accessible )
I will try again in the am.
Tim
Unfortunately
Tim
Upload is still in progress. It will be in place by tomorrow.
Thankfully, download will be quicker...
Hi Irads!
It seems to be that the links are broke, I just can download part 1 of the image
Could you check it please?
I would like to set it up new after some "testing and updating" as nolinux-user
(had problems with xscreensaver and the driver-performance)
Thanx in advance,
Stephan.
Thanx in advance,
Stephan.
Maybe upload was not complete by the time you downloaded.
Seems OK now.
Seems OK now.
Hi Irads!
Thanx4Response & sorry, I overlooked the date, I thought the last post is older - but: other links still broke (checksums & part 1 ok), just4info.
I'll try again tomorrow,
regards,
Stephan.
regards,
Stephan.
There are still problems concerning the download locations.
This afternoon I was only able to download part 1. This evening part 2 was available.
The other links give a 404 error.
Is this a continous issue, or are you updating the image every now and then...removing the old image and uploading through a slow uplink?
If the latter is the case, maybe a version number should be incorporated into the name of the image. Just a suggestion.
Please be patient. It is not a version update but just an initial upload.
Well, that is fine by me. But you got us all confused by stating a while ago:irads wrote:Please be patient. It is not a version update but just an initial upload.
Still, after 2+ days, only the first 2 parts are uploaded. But I am not in a hurry, so I will check it next week.irads wrote:Maybe upload was not complete by the time you downloaded.
Seems OK now.
The recovery image works fine.
Actually this post is made from the Fit-PC2 using this image.
