Recovery image contains the same linux as preinstalled on hard drive, you can use it as hard drive replacement if you want.jens wrote:In case I boot the recovery image from a usb stick and run the installer, will
this erase all data on my hard drive? Or will I be able to partition my disk
and perhaps also create a dual boot from this installer?
Best,
Jens
On the Desktop you can see script os_installation_fitpc2 that do next things:
- Creates partitions on hard drive with fdisk utility.
- Restore partition with partimage utility.
- Installs grub in mbr.
If you have some scripting skills you can edit this file to set desired partition sizes and save any space you want for dual boot.
