Failure of live and install from USB Key on Fit-PC2
mduckett
Post by mduckett »
Have a Fit-PC2 D1G-C1600 W-H8 with 8GB SSD drive. Have tried a range of usb boot tools with Mint 9/Ubuntu 9.10 Desktop. I tried live and install modes. In all cases, the process begins then I lose video (black screen). Using supplied HDMI to DVI cable. Also tried a different HDMI to DVI cable with same results. Tried different USB ports on the PC2 and also different USB drives.
I can't seem to get either live nor install of Linux Mint or Ubuntu to work.
Any suggestions? After 2 days of trying permutations, I'm ready to return the Fit-PC2.
Thanks for any ideas you may have.
Re: Failure of live and install from USB Key on Fit-PC2
Please add
vga=0x31A
to the boot command option. I suggest you to try the YUMI tool to prepare the installation USB stick
mduckett
Post by mduckett »
Changed boot option to vga=0x31A
The end result is the same, black screen (no video).
I seem to get a few additional flashes and strange colors but nothing further. I am using the hdmi/DVI cable provided.
Any other suggestions?
Can you please try another monitor?
Return to “Ubuntu 9.10”
