Bootproblems - Ubuntu - initramfs
user89
Post by user89 »
Hi, i have problems with my fit pc 2.
OS: Ubuntu (Server) 9.10
Yesterday i made an update.
Update - commands:
apt-get update
apt-get upgrade.
After the Update, the system don´t boot.
This message comes at boot: initramfs
What should I do?
Thanks a lot for your help.
fly
Re: Bootproblems - Ubuntu - initramfs
Post by fly »
Please provide more specific information about the boot error and the packages upgraded before. If the update was installing a new kernel, you might want to switch back to your previous one. A backup should have been placed in your grub menu.
user89
Post by user89 »
Hi fly,
thanks for your answer.
How can I read this from the system (specific information about the boot error and the packages)?
How do I do that?
Thanks a lot for yor help!!
fly
Post by fly »
Well, you ordered the system to download and install updates, you should have had a look them before. Never ever install updates, just because an automated system tells you that it's good/checked/tested/wont do any harm. However, there should be a log file at /var/log/dpkg.log
How do I do that?
Uhm, on 10.04 it's the ESC which envokes the menu, however you might just want to look at your grub configuration. If you installed a clean 9.10, you will have grub2, so you might want to look at [1]:
According to an email that was sent out today Monday, August 10, 2009 with the newest Grub2 update, the boot menu is hidden by default now. It's easy to get it back, just edit /etc/default/grub and comment out GRUB_HIDDEN_TIMEOUT
$ sudo nano /etc/default/grub
Make your timeout line look like this...
#GRUB_HIDDEN_TIMEOUT=3
GRUB_TIMEOUT=XXX        <---Make sure you put in a timeout value here.
Save the file and exit, then run...
$ sudo update-grub
[1] https://wiki.ubuntu.com/Grub2#Where%20did%20my%20Grub2%20boot%20menu%20go!?!?!
user89
Post by user89 »
Hey fly,
The System don't find the file. In the folder that file is only available:
console-setup.
What should I do?
thanks for your help!
fly
Post by fly »
It's not quite easy to identify problems remote via a webforum. I can just guess. Given the time difference, this might not be critical, so why don't you just reinstall the system from scratch? Yep, it's a windows like approach, but I think this can be done in a matter of hours while diagnosis (and testing and fixing..) here will take some time...
Return to “Ubuntu 9.10”
