Ubuntu 9.10 supported
Posted: Mon Nov 30, 2009 10:55 pm
Hi all,
Ubuntu 9.10 is officially supported. There are new graphic drivers available (beta version) - IEGD IntelĀ® Embedded Graphics Drivers.
Prepare installation media
- You can use USB CD-ROM Drive or USB Flash drive (disk-on-key) as installation media.
- Download Ubuntu 9.10 Desktop installation
- If you are using USB CD-ROM - burn downloaded image directly on CD.
-If you are using USB Flash drive, 1GB would be enough. Download usb-creator to create bootable installation flash drive.
Installation of generic Ubuntu 9.10 Desktop
- Standard Ubuntu installation - choose timezone, partitions, username, password etc.
- Unplug USB CD-ROM / USB Flash drive and reboot
- Login using previously selected username and password
Required system changes
- Add the following lines to /etc/apt/sources.list
- Refresh update manager
- Install kernel image, kernel headers, graphic drivers and media player for HD playback:
- Comment out snd-hda-intel options in /etc/modprobe.d/alsa-base.conf
- Remove generic image and sources that are not fully compatible with fit-PC2.
- Restart fit-PC2
Ubuntu 9.10 is now installed.
Known issues:
- Suspend and Hibernate functions do not work properly and disabled in kernel. Using these functions is equal to Lock Screen.
## Repository for fit-PC2 users provided by Compulab
deb http://fit-pc2.com/download/ubuntu/dists/karmic binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/karmic source/
sudo apt-get update
sudo apt-get install linux-image-2.6.31-34-fitpc2 linux-headers-2.6.31-34-fitpc2 xserver-xorg-video-poulsbo mplayer-vaapi mplayer-skins
# Power down HDA controllers after 10 idle seconds
# options snd-hda-intel power_save=10 power_save_controller=N
sudo apt-get purge linux-generic linux-image-generic linux-headers-generic linux-image-$(uname -r) linux-headers-$(uname -r) && sudo apt-get autoremove
Known issues:
