I have four FIT-PC2's that I need to get set up, so this is becoming a pressing issue for me.
My hardware is FIT-PC2 Ubuntu, fairly fresh from the factory. Out of the box the wireless does not work. They came with Ubuntu 9.10 working fine, but no wireless.
Here's my problem:
-Wireless does not work. I've attempted to install the rt3090 wireless driver twice, no effect.
-Running an iwconfig scan tells me that the device "is not capable of scanning"
-Pulling up the dropdown menu at the top says that the device is disconnected.
Wired internet works fine.
These machines are going on customer's robots, so I need to find a solution sometime soon...
Lack of Wireless Function
Re: Lack of Wireless Function
Hi craighickman
A bit on limb here.. But have you update with the fitpc2 kernel and xserver driver hosted by compulab ..?
Here is the referring link..
http://fit-pc2.com/wiki/index.php?title ... buntu_9.10
If you already installed the repo, and updated accordingly, and it still does not work, report back after running the command.
In terminal
$ lspci
You might wanna direct it too a file for easy cutting and pasting..
$ lspci >> ~/sample.txt
(the output will be a file called "sample.txt" in your home dir.
Cheers.
W.
In terminal
$ lspci
Cheers.
W.
I'm not at work anymore, but I'll give this a try tomorrow and get back to you on whether it works.9812713 wrote:Hi craighickman
In terminal
$ lspci
Cheers.
W.
Found the issue.
I had been using dd to copy a "working" operating system across to the FIT-PC's. Turns out the "working" one had a bad spot on the disk, right where the wireless drivers were sitting.
All better now.
All better now.
Thank for the report.
