WinServer 2003 R2 and unknown 2 PCI-Devices.
Hi there.
I have succesfully installed WinServer 2003 R2 SP2+ into this great hw.
I gave all drivers,chipset, gfx, audio, IR, Wifi, Ethernet but still there is 2 unknown PCI-Devices.
What are those?
What are those?
Re: WinServer 2003 R2 and unknown 2 PCI-Devices.
Please list their Vendor ID and Device ID.
Both
PCI\VEN_8086&DEV_811C&SUBSYS_81198086&REV_07\3&B1BFB68&0&F0
PCI\VEN_8086&DEV_811D&SUBSYS_81198086&REV_07\3&B1BFB68&0&F1
? any progress. were the data correct i gave you?
I will check today, thanks.
Hi, Jeremys.
These devices refer to SDA Standard Compliant SD Host Controller.
Windows should load its driver automatically.
Leonid Firdman
well, I tried to install those with automatic scan all over the system, but winServer 2003 R2 Sp2+ did not found mathing drivers... strange.. i'll try later again and raport here.
If you don't want to use the mini-SD card reader that is built-in in the Fit-PC2, then I assume you wouldn't need those drivers at all. Or maybe you can also try Windows XP drivers for those, and see if it works.
so, the drivers are for MiniSD? Of course i want everything to be in order.
Where do I get the drivers?
Well, any progress with this one. I installed the system again but winSev did not found any drivers for these mysterious pci-devices..
where may I get those?
