Windows Vista Ultimate
BenS
Post by BenS »
I just installed Windows Vista Ultimate on my fit_PC2.
I used a USB DVD-drive to install windows. We tried with a USB-stick, but that didn't work.
At first I had some problems in installing Vista. Then I started with XP and installed Vista.
Some drivers where unknown to Vista. Here are the ones I needed to install:
Drivers:
- Realtek 1000 BaseT Ethernet :
ftp://61.56.86.122/cn/nic/Driver_Vista_6223_0526.zip
- 802.11g WLAN : RaLink RT3090 :
http://www.ralinktech.com.tw/data/drive ... 0_Free.exe
_ AVR309: Software Universal Serial Bus (USB)
http://www.avrfreaks.net/index.php?func ... ks%20Tools
The speed of the OS is OK!
Keep in mind that you need half a day to install the Vista-updates.
I advise you also not to use the Windows Search (under services), otherwise you're OS is indexing all the time.
I'm happy with the result. The fit-PC2 is now running my HomeControl-programm.
Success with your fit-PC2
Rootax
Re: Windows Vista Ultimate
Post by Rootax »
Is Aero working ? What graphic driver is installed ?
Thx :)
ender
Post by ender »
At least in Windows 7, Aero works, but it's so slow it's unusable.
Rootax
Post by Rootax »
I think i've a problem with my fit-pc2 then, because even without Aero, the display is very slow, and i don't know why but it's like the cpu is doing all the job.
When i open the task manager, the task manager process itself take 20-25% of the cpu. If i switch to Aero, then the dwm process take 20-25% of the cpu too....
I'm on vista ultimate sp2, indexing is disable, and my gma500 drivers are 7.14.10.1005 (the last one from intel atm).
LEGOManiac
Post by LEGOManiac »
Can you update the links? One is no longer valid and one requires a password to log in to the FTP site.
