WinServer 2003 R2 and unknown 2 PCI-Devices.
Windows Vista, Windows 2000, XP Embedded, Windows CE, Windows Server etc.
jeremys
Re: WinServer 2003 R2 and unknown 2 PCI-Devices.
Post by jeremys »
I'm sorry, but can anyone help me with these 2 missing pci-devices? where to get xp drivers?
jeremys
Post by jeremys »
I hate to ask again, but is there anyone from hw-side investigating this? Widely used ServerOS and missing drivers with pure install.. :roll:
sideawake
Post by sideawake »
Same problem here. I installed all the driveres offered, but 2 unknown PCI devices remain. Please, can someone from Compulab elaborate on this?
CompuLab does not support WinServer.
yogev_ezra
Post by yogev_ezra »
Windows XP has the drivers as part of the distributive - they are not related to Compulab. The driver file names are
sdbus.inf
sdbus.sys
I have attached the files here, but not sure Windows 2003 will accept them.
Again, to clarify - this is not Compulab problem but Windows 2003 problem, since Windows XP (and Windows 7) have them as part of Windows installation. The fact that Windows 2003 misses them might indicate that standard SD cards are not supported.
sdbus.zip
(41.94 KiB) Downloaded 661 times
sideawake
Post by sideawake »
Thank you, yogev_ezra! It worked for me.
(To install the driver in sdbus.zip, one also need sdhcinst.dll, but that file can be found on the web.)
jeremys
Post by jeremys »
Can't wait to test this! THANK YOU for all the trouble.
jeremys
Post by jeremys »
Sweet.
I extracted these .sys & .inf files from XP SP3 package and compaired those with here attached: same they are. only the DLL from the web was someshat different (i took XPSP3 version).
WinServer 2003 R2 pack did not have those files at all.
Device manager shouted "not signatured blah blah.." Yes and there they were: two SDA compilant things. :))
EDIT: I'll test some mini/micro SD(HC) cards today. :)
EDIT2: Specs says "MiniSD" but I just could not get the miniSD card to go in there!! Almost but not. Card is too wide! Howcan?
yogev_ezra
Hi there,
I am glad the files worked for you, but can you please test whether the SD cards are working now? And if they do, can you please attach in this thread the files you used so that everyone could benefit? ;)
yogev_ezra
jeremys wrote:EDIT2: Specs says "MiniSD" but I just could not get the miniSD card to go in there!! Almost but not. Card is too wide! Howcan?
You sure your card is MiniSD and not SD and that you are inserting it correctly? My MiniSD card goes in fine (it makes a small click when it is locked inside).
Return to “Other Windows versions”
