Playback a chuppy on files from a Sony Cybershot 720p
Video playback in Windows
sune
Post by sune »
Hi again,
My new FIT PC2 XP playes videofiles generated on a Sony Cybershot DCS-WX1 chuppy. Most of the time it is smooth, but every 5-8 seconds it makes a stop/go.
The FIT PC is setup with a screen resolution of 1360x768.
Im playing i fullscreen mode using the Media Player classic delivered as part of the pc.
Any idears. I have a lot of thees files, and will get more:-)
Br
Sune
Re: Playback a chuppy on files from a Sony Cybershot 720p
what is the file format?
sune
Post by sune »
MPEG4, 1280x720, 29,97fps
Audio: AAC 384kbps
How do I see the codec name?
Have tried to set my resolution to 1280x720. It does not help. It plays smoothly if the video windows is made small.
mvh
Sune
sune
Post by sune »
The format is DivX/Xvid.
I did go for the Windows XP version as you mention that as the multimedia pc on your homepage.
Would I have been better off by changing it to a Win7 version? Or, is there drawback there. Use of the Fit-PC: Connected to our TV, it shall be used for music, pictures and videos (DVD and own videos).
/Sune
to see codec name right click in mpc-hc during playback and look under filters.
there is a chance mp4 playback will be better in win7
sune
Post by sune »
I think the codec is MPEG2, but not sure. The information is below.
However, if you open the files with AVS Video converter, it mentioned the compression type as MPEG4 (DivX/Xvid)
Br
Sune
Filter : ffdshow Video Decoder - CLSID : {04FE9017-F873-410E-871E-AB91661A4EF7}
- Connected to:
CLSID: {55DA30FC-F16B-49FC-BAA5-AE59FC65F82D}
Filter: C:\Documents and Settings\Home\Desktop\M4H00160.MP4
Pin: Video
- Connection media type:
Video: MPEG4 Video 1280x720 29.97fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {5634504D-0000-0010-8000-00AA00389B71}
formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA}
bFixedSizeSamples: 0
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 160
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333666
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 16
dwPictAspectRatioY: 9
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
MPEG2VIDEOINFO:
dwStartTimeCode: 0
cbSequenceHeader: 28
dwProfile: 0x00000000
dwLevel: 0x00000000
dwFlags: 0x00000000
BITMAPINFOHEADER:
biSize: 40
biWidth: 1280
biHeight: 720
biPlanes: 1
biBitCount: 24
biCompression: MP4V
biSizeImage: 0
biXPelsPerMeter: 1
biYPelsPerMeter: 1
biClrUsed: 0
biClrImportant: 0
This filter does not use HW acceleration.
sune
Post by sune »
OK, not optimal for me.
However, I can convert the videos to H264. It will work.
Do you think it will work if I use Win7 instead. I could make a deal with my local reseller. But, If it does not make a difference Im perfectly happy with the current XP version. Just your best guess, pelase?
H264 on XP is the best.
Windows 7 has built-in codecs that support H264, MPEG4 and WMV. I believe that at 720p they will be adequate.
Another thing you can try is Mplayer with FFMPEG on XP. Still without acceleration, but just enough to playback 720p decently.
Return to “Video playback”
