As Cable Replacement?
Jazz
Post by Jazz »
Would this work for Boxee, Hulu, and Netflix? Maybe streaming media over a network?
Also, what interface does this use for expansion? MiniPCI? I would like to stick my own wireless card in it.
Thanks!
yogev_ezra
Re: As Cable Replacement?
Post by yogev_ezra »
According to Compulab's current policy, sticking your own card in the expansion socket would void your warranty.
Regarding Hulu and Netflix - you can check reviews of flash based application performance on other Atom based systems. Flash is mostly CPU dependent. Generally standard definition flash video works fine. High definition flash video drops frames.
Return to “Using fit-PC2”
