Booting off CF Card
cKBoy
Booting off CF Card
Post by cKBoy »
Is it possible to boot off CF with a diskless Fit-PC?
RKz
Re: Booting off CF Card
Post by RKz »
If you mean the miniSD card, no, but a regular Compact Flash can be used with a special adapter that makes it look like a 2.5" HD.
Richard Klingspetz
System Technology Sweden AB
advid
Post by advid »
I tried to use a sandisk Compact Flash 4GB with a SATA adaptor as a small SSD.
When I go F2 to BIOS settings a can see the Compact 4GB as a primary drive. 8-)
I managed to install the Mageia 1 Linux from the Live CD to the CF, which is seen as /dev/sda.
No problem here. :)
Grub setup on disk MBR, /dev/sda is my choice.
I check again the BIOS: the drive, the only one, is set as boot device.
Then, I boot the FitPC2i and it can't find any OS. "no operating system found"
It just don't boot the CF ! :cry:
I tried to chain boot the CF with Grub on my bootable USB key: Grub doesn't see any disk, except the key itself. :?
Any idea please ?
advid
Post by advid »
Self-reply :
I've found a page which claims that even if my CF-SATA adapter is bootable, not all CF are bootable ... :cry:
(and the compatible ones advertised are very expensive)
I think I'll go back trying to boot of SD...
Hello
We didn't test such adapters, so there may be a problem with an adapter. Before you are going to buy a bunch of different cards, please try them first
advid
Post by advid »
The SSD price have droped a lot, I've just bought 64GB SATA SSD to get rid of usb keys and have higher speed. 8-)
64GB is too much, I needed 8GB at most, but it's only 37€ so...
This time there won't be any problem to boot I hope :roll:
The CF Card and its adapter were just wasted money :cry:
Return to “Using fit-PC2”
