XP Pro Install
grnbriar
XP Pro Install
Post by grnbriar »
We must have XP Pro for Remote Desktop access to the Fit PC 2 and other networking tools. We have a full XP Pro SP3 version to use to upgrade from the XP Home that will come with the unit.
Is there anything special, extra drivers to install, etc, that must be done to move to XP pro, or will the standard installer work?
We've decided the standard windows versions you will be offering with WiFi will work for us, if we can upgrade to XP Pro.
Leonid
Re: XP Pro Install
Post by Leonid »
There is no difference between drivers for WinXP Pro and WinXP Home editions.
Leonid Firdman
yogev_ezra
Re: XP Pro Install
Post by yogev_ezra »
Windows XP drivers are available for download here: http://www.fit-pc2.com/download/xp-drivers/
If you order Fit-PC2 with XP Home installed, the drivers will be already pre-installed too. If you then install XP Pro over XP Home, it will keep the drivers.
If you decided to purchase Fit-PC2 without Hard Disk or with Linux installed and then install a fresh XP Pro, then you can use the drivers provided in that link.
Return to “XP installation”
