can't boot but can access bios
oldtimer
Post by oldtimer »
I got my fit-PC2 SSD back in January, but did not use it much
because I didn't have a monitor that went well with it.
Now I have the monitor adapter, but it will not boot.
There is just a flashing cursor but typing has no effect.
If I hold F2 I can enter the bios settings and the keyboard
works to change them. The default OS is set to WinXP and
the various boot media are enabled.
Re: can't boot but can access bios
Apparently the problem has to do with storage device or installation of operating system.
- Are you sure you have an operating system installed on the SSD ?
- Please check if SSD is detected in BIOS.
- Make sure you do not have a thumb drive attached that takes precedence over SSD in boot order.
Return to “fit-PC2 BIOS”
