IEGD vs. GMA500 driver
ios
Post by ios »
Why are there actually two graphics driver packages - the GMA500 and the IEGD?
I read the GMA500 means more performance - is that right? Is there any reason for using the IEGD then?
Regards
fabbe72
Re: IEGD vs. GMA500 driver
Post by fabbe72 »
As far as I know, you are only required to use the IEGD driver when tou want to operate your fit-PC2 headless, i.e. without monitor.
If you plan on using your fit-PC2 as an normal computer or HTPC with a display device attached to it you would do best using only the GMA 500 driver.
Good luck!
Return to “Display driver”
