DisplayLink device under Windows 7 and Windows XPSP3
Posted: Sun Sep 20, 2009 3:30 am
I bought a USB VGA adapter that uses DisplayLink's DL-165 chip. It worked very well under Windows 7 until I changed my OS to Windows XP because of the limited amount of memory of Fit-PC2. Under Windows 7, I was able to plug in ONLY the USB VGA and boot up the system. The monitor connected to the adapter will be recognized and used as the Primary Display. However, under Windows XP when I boot the system up, the LED on the adapter will go one and then go off again without anything displayed on the screen. At this point if I hook up an HDMI monitor I will see the XP desktop displayed in a very low color depth (8bit I guess). As soon as I switched this desktop to 32bit color the USB VGA adapter started working. I tried both DisplayLink's current driver and the new beta driver but end up with the same result.
I wonder if this is a Windows XP issue? Is there any successful case of using a similar USB VGA adapter?
