Resolution setting and HDD detection
Posted: Fri Jul 31, 2009 12:28 am
by Spoon
I have combined my diskless Fit-PC2 C1600 with the harddisk WD500BEVT and have involuntary tried several scenarios:
1) Ubuntu 8.04LTS DVD cannot not detect a harddisk
2) Ubuntu 9.04 does sometimes
3) Ubuntu 9.10 does
4) openSuse 11.1 also does
The installation of Ubuntu 8.04 and 9.04 stops from time to time and proceeds after pressing the Num-Lock-Key. In addition I can't step over 480p with my 1920x1200 50/60Hz display HD2441W, even with the latest BIOS from 21/07/09.
Are there any ideas what is wrong?
My modiefied BIOS settings are:
* Large Disk Access Mode [Other] DOS
* Installed O/S [Other] Windows...
* NumLock [Off] On
* Intel Virtualization Technology [Enabled] Disabled
Update
Posted: Sat Aug 01, 2009 11:25 pm
by Spoon
No idea, does not matter.
My warning: Ubuntu 8.04.3 and openSUSE 10.3 does not support the 500GB HDD.
The display problem is gone, either the HDMI ports are not DVI compatible or the HDMI cable is out of spec., the DVI port of the monitor works (VESA).
Re: Resolution setting and HDD detection
Posted: Sun Aug 02, 2009 3:20 am
by quagga
I'd reset your LBA settings back to the default and try again. Actually I'd probably reset all of the BIOS settings to default.
Posted: Sun Aug 02, 2009 1:10 pm
by Denis
Please follow this guide: http://www.fit-pc2.com/forum/viewtopic.php?f=9&t=655
harddisk identification for 8.04 solved, dedicated psb driver will be installed instead of vesa.
