graphics driver poulsbo gma500 for Slackware 14.0
Display driver and X11
larse
Post by larse »
Last month I got a fitpc2 -bought 2011- from a friend.
He had installed Windows7, Mint9 and Slackware14.0, the latter used as a server (SMS-2.0.7-version). -I remember his first comments about the Slackware install in 2013 that he could not make the graphics working due to no drivers. At first 2014 he got the graphics working.
Now when I booted up the fitpc2 for the first time I noticed that the best resolution I was able to set was 800x600@86 Hz, same in Mint. In Slackware he used the vesa driver, in Mint the emgd. Also noticed he had blacklisted the gma500 driver in Slackware. Since he was a very skilled Slackware user I assume he made the blacklist for some specific reason. (later I can add: I tried the gma500_gfx myself: It made me not even being able running Slackware in run level 3!)
I can push the video reolution to 1280x1024 through editing xorg.conf, but with the loss of Refresh rate, that is Refresh rate is locked at 0 Hz.
I know this by now is a somewhat "old" question, but is there any way to get a better 2D resolution in Slackware14.0 for this fitpc2?
Some information about my hardware
# hwinfo --gfxcard
09: PCI 02.0: 0300 VGA compatible controller (VGA)
  [Created at pci.319]
  Unique ID: _Znp.DlGhUSFiV2D
  SysFS ID: /devices/pci0000:00/0000:00:02.0
  SysFS BusID: 0000:00:02.0
  Hardware Class: graphics card
  Model: "Intel System Controller Hub (SCH Poulsbo) Graphics Controller"
  Vendor: pci 0x8086 "Intel Corporation"
  Device: pci 0x8108 "System Controller Hub (SCH Poulsbo) Graphics Controller"
  SubVendor: pci 0x8086 "Intel Corporation"
  SubDevice: pci 0x8119
  Revision: 0x07
  Memory Range: 0xb0080000-0xb00fffff (rw,non-prefetchable)
  I/O Ports: 0x1810-0x1817 (rw)
  Memory Range: 0xc0000000-0xcfffffff (rw,non-prefetchable)
  Memory Range: 0xb0000000-0xb003ffff (rw,non-prefetchable)
  IRQ: 7 (no events)
  I/O Ports: 0x3c0-0x3df (rw)
  Module Alias: "pci:v00008086d00008108sv00008086sd00008119bc03sc00i00"
  Driver Info #0:
    Driver Status: gma500_gfx is not active
    Driver Activation Cmd: "modprobe gma500_gfx"
# hwinfo --monitor
23: None 00.0: 10000 Monitor
  [Created at monitor.95]
  Unique ID: rdCR.dOpLEWE6aiC
  Hardware Class: monitor
  Model: "PHILIPS 109P4"
  Vendor: PHL "PHILIPS"
  Device: eisa 0x0008 "PHILIPS 109P4"
  Serial ID: "BZ  170234"
  Resolution: 720x400@70Hz
  Resolution: 640x480@60Hz
  Resolution: 640x480@72Hz
  Resolution: 640x480@75Hz
  Resolution: 800x600@60Hz
  Resolution: 800x600@72Hz
  Resolution: 800x600@75Hz
  Resolution: 832x624@75Hz
  Resolution: 1024x768@60Hz
  Resolution: 1024x768@70Hz
  Resolution: 1024x768@75Hz
  Resolution: 1280x1024@75Hz
  Resolution: 1920x1440@60Hz
  Resolution: 1792x1344@75Hz
  Resolution: 1600x1200@85Hz
  Resolution: 1280x1024@85Hz
  Detailed Timings #0:
     Horizontal: 1600 1664 1856 2160 (+64 +256 +560) -hsync
       Vertical: 1200 1201 1204 1250 (+1 +4 +50) -vsync
    Frequencies: 229.50 MHz, 106.25 kHz, 85.00 Hz
  Driver Info #0:
    Max. Resolution: 1920x1440
    Vert. Sync Range: 50-160 Hz
    Hor. Sync Range: 30-111 kHz
    Bandwidth: 229 MHz
  Config Status: cfg=new, avail=yes, need=no, active=unknown
Regards
Lars
Re: graphics driver poulsbo gma500 for Slackware 14.0
forwarded to our linux expert...
Return to “Display driver”
