mplayer: marker does not match
Posted: Mon Aug 17, 2009 12:05 pm
by ahk05
Hi
I can play HD mkv files and wmv files on mplayer with no problems, but when I try to play a standard Xvid file I get the following spammed out in the console again and again, and the video lags (I've also seen some squares on the video like "lagging behind" during the entire playback, but they are not always there). To me it sounds like lag caused by the console spamming, but in fact the cpu load is only about 14%. I'm using Ubuntu 8.04 as described here. The video plays perfectly on my desktop pc and almost perfectly in totem/vlc player on the Fit-pc2 (but with some screen tearing). Any ideas?
[mpeg4 @ 0x895f520]marker does not match f_code1 ??% ??% ??,?% 0 0
[mpeg4 @ 0x895f520]marker does not match f_code3 ??% ??% ??,?% 0 0
[mpeg4 @ 0x895f520]marker does not match f_code5 ??% ??% ??,?% 0 0
[mpeg4 @ 0x895f520]marker does not match f_code7 ??% ??% ??,?% 0 0
[mpeg4 @ 0x895f520]marker does not match f_code9 ??% ??% ??,?% 0 0
The video information from mplayer is as follows:
VIDEO: [XVID] 624x352 12bpp 23.976 fps 996.2 kbps (121.6 kbyte/s)
Clip info:
Software: VirtualDubMod 1.5.10.2 (build 2540/release)
ID_CLIP_INFO_NAME0=Software
ID_CLIP_INFO_VALUE0=VirtualDubMod 1.5.10.2 (build 2540/release)
ID_CLIP_INFO_N=1
ID_DEMUXER=avi
ID_VIDEO_FORMAT=XVID
ID_VIDEO_BITRATE=996168
ID_VIDEO_WIDTH=624
ID_VIDEO_HEIGHT=352
ID_VIDEO_FPS=23.976
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=85
ID_AUDIO_BITRATE=152232
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_LENGTH=5055.09
ID_SEEKABLE=1
ID_CHAPTERS=0
And when playing:
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
[VD_FFMPEG] VA API accelerated codec.
[VD_FFMPEG] Trying pixfmt=0.
VDec: vo config request - 624 x 352 (preferred colorspace: MPEG-4 VA API Acceleration)
VDec: using MPEG-4 VA API Acceleration as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [vaapi] 624x352 => 624x352 MPEG-4 VA API Acceleration
[VD_FFMPEG] XVMC-accelerated MPEG-2.
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
ID_VIDEO_CODEC=ffodivx
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
ID_AUDIO_BITRATE=128000
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
ID_AUDIO_CODEC=mp3
Starting playback...
[mpeg4 @ 0x895f520]Invalid and inefficient vfw-avi packed B frames detected
Movie-Aspect is 1.77:1 - prescaling to correct movie aspect.
ID_VIDEO_ASPECT=1.7727
Re: mplayer: marker does not match
Posted: Mon Aug 17, 2009 2:24 pm
by Denis
Please open such videos with VLC or Totem media players.
Unfortunately mplayer-vaapi is not official part of Ubuntu yet and not very well maintained.
Please post link or attach part of videofile that cause mplayer-vaapi failure, may be I or someone else will try to fix it.
