S/PDF -> RCA
Audio codec and audio ports
remaille
S/PDF -> RCA
Post by remaille »
I am a bit confused about the audio output on the fitpc2i...
Is it possible to plug an analog jack into the S/PDF line out ? Headphones ? jack to RCA cable ?
I would like to send the audio to an old analogic HI-Fi system.
Thanks.
Rémi.
Re: S/PDF -> RCA
Yes, you can get analog stereo from line-out. You can use 3.5mm to dual RCA cable for that.
remaille
Re: S/PDF -> RCA
Post by remaille »
irads wrote:Yes, you can get analog stereo from line-out. You can use 3.5mm to dual RCA cable for that.
Plug it into the numeric S/PDF ? It has too analogic output ? i thought this was not possible.
Thanks.
Re: S/PDF -> RCA
The same jack supports both digital S/PDIF and analog line-out.
Return to “Audio”
