WiFi malfunctioning on Windows HD model
grnbriar
Post by grnbriar »
The Wifi seems to 50/50 see the local network or not when the system boots. And if connected, drops the connection and reports no network about every 2-3 minutes. Can generally connect again manually within a couple of minutes, but then it drops it again. The signal strength always shows as Strong, when it sees the network, and no other device in the room is having a wifi issue.
Any known issues with Wifi and Windows? The system is not useable as is.
(System is stationary and about 15 feet from the wifi point.)
Re: WiFi malfunctioning on Windows HD model
I'm not familiar with WiFi behavior issues. I suggest trying first the full suite of RaLink driver & utility from http://www.ralinktech.com.tw/data/drive ... 0_Free.exe
See if behavior improves when using it rather than Windows zero config.
ble0t
Post by ble0t »
I am also experiencing this issue and I have tried the full Ralink installation, although their management software actually seemed to make the issue worse.
According to Compulabs website, the chipset used is a Realtek compatible one, so are their specifications different from what we have?
Also, there are 4 driver sets that come in the archive that is provided on this site for WiFi drivers. Why?
yogev_ezra
Post by yogev_ezra »
The Fit-PC2 Value WiFi is shipped with Realtek. This to decrease the unit total cost (Realtek is 5$ cheaper than Ralink). Other models that have WiFi are shipped with Ralink: http://fit-pc2.com/wiki/index.php?title ... ailability
The other 2 drivers suit the WiFi cards that were used in test units.
We are investigating these reports. A unit with the reported problem should arrive at our lab in a few days.
gazza
Post by gazza »
Any updates on this one ?? I also have this problem and it's very frustrating. Please let us know if you need serialnumbers or similar.
Reg. Gazza
Check http://fit-pc2.com/forum/viewtopic.php?f=30&t=532
If this doesn't help, compare WLAN performance to other devices on the wireless network and if fit-PC2 shows significantly worse behavior, please consult rma@fit-pc.com
