fit-PC2 Rev1.41 miniPCIe USB Line disabled?
foolstome
Post by foolstome »
Newly purchased fit-PC2 (rev1.41) wont recognize miniPCIe cards which uses USB line on miniPCIe socket.
Document says "mini PCI Express includes PCIEx1, USB (EHCI), SMB, power supplies."
http://compulab.co.il/wp-content/upload ... -Guide.pdf
Is there any change of hardware specifications? without noticed?
Re: fit-PC2 Rev1.41 miniPCIe USB Line disabled?
There were no changes made. Can you please specify what cards do you use?
foolstome
Post by foolstome »
I checked both Intel Centrino Advanced-N 6230 and 6235 mini PCIe card that uses USB line for Bluetooth function.
And both card works only Wi-fi function, but bluetooth never show up in device manager of windows7.
This USB port support only USB2 devices. To the best of my knowledge, a bluetooth modules use the USB 1.1 standard. Please check it with your cards' datasheet.
foolstome
Post by foolstome »
gabrielh, you mean that fit-PC2 miniPCIe`s USB line only support EHCI like USB P2(front left USB mini port)?
Is it standard miniPCIe specification? or fit-PC2 specified limitation?
Anyway, I will try 4G WiMAX combo card(WiMAX uses USB2.0 only) if the problem stands for miniPCIe`s USB line spec.
The only limitation for the FitPC2's miniPCI port, is the US15W USB2 port with no USB1.1 backward compatibility
foolstome
Post by foolstome »
OK, I tried Intel Centrino Advanced-N 6250(WiMAX combo card. WiMAX device uses USB2.0 because of its transfer speed).
well, result is... It work! WiMAX part shown up in device manager.
So, I have to find Bluetooth combo card which work with USB2.0 port...ughh.
