Poor link quality in Ubuntu
MSX
Post by MSX »
Hello, i've set up the wireless in ubuntu 9.4
It's all working (i can connect and all) but the link quality is quite bad, i can't figure out why.
Here's my iwconfig output:
nicola@serv:/etc/network$ iwconfig wlan0
wlan0     IEEE 802.11bg  ESSID:"Lair"
          Mode:Managed  Frequency:2.447 GHz  Access Point: 00:18:xx:xx:xx:xx
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Retry min limit:7   RTS thr:off   Fragment thr=2352 B
          Power Management:off
          Link Quality=16/100 Signal level:65/65
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
Note that link quality is very bad but signal level is at max, indeed the server is very near the router (a couple of meters).
Here's my /etc/network/interfaces file:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
auto wlan0
iface wlan0 inet static
        address 192.168.0.6
        netmask 255.255.255.0
        network 192.168.0.0
        broadcast 192.168.0.255
        gateway 192.168.0.1
        dns-nameservers 192.168.0.1
        wireless-essid   Lair
        wireless-key     xxxxxxxxxx
        wireless-channel 8
        wireless-mode    managed
any idea ?
Evilworm
Re: Poor link quality in Ubuntu
Post by Evilworm »
Maybe you have a faulty antenna? The stock antenna is pretty small and does not cover a large area, too. Also you might try to switch to a different channel if you have a noisy neighborhood...
