Dear all,
have a fitpc2 which is running quite happily. I want to replace the current 750gb hd with one of these:
https://www.amazon.co.uk/Seagate-BarraC ... b_title_ce
Seagate BarraCuda 2 TB 2.5 Inch Internal Hard Drive (7 mm Form Factor) - will that fit? Should be ok apart from that?
Thanks for your help.
BW
FitPC2 - use 7mm Drive
Re: FitPC2 - use 7mm Drive
A 2,5" drive in a 7mm form factor should fit in mechanically in the fit-pc2 and as far as I know SATA3 should be backward compatible on HDD's.
Besides that, we haven't validated the functionality of this HDD with this platform, hence we cannot guarantee it would work.
