SSD not detected anymore
ar_bin
Post by ar_bin »
I reactivated my fit-PC2 after a couple of years and as expected, the C-MOS setup battery was empty. I can enter and safe the C-MOS setup, but my SSD is not detected anymore, no matter, what setting I try, I get: Primary Master: None. (Same as when I take out the SSD) The PC was running under Linux with this SSD before. BIOS: 03/18/09. Any hint?
Thanks, best regards
tamir
Re: SSD not detected anymore
Post by tamir »
Does other SSD in the same form factor is not recognized as well?
Does this component is recognized on a good known working system?
