Is the fit-PC2 XP HD capable of playing the very heavy AVCHD H.264 videos the Hauppague HD PVR creates. I've read in the forums that it should be capable of playing these, but I wanted to see if anyone has actually used one to encode and to watch using the Hauppague HD PVR.
thanks in advance
FIT and Hauppague
Re: FIT and Hauppague
If you can upload a sample somewhere, we can test.
Thanks.
Here's a sample
http://www.sendspace.com/file/n6jqv4
here's a 720P sample. The other download is too slow
http://dl.getdropbox.com/u/434402/blog/dhdt-30sec.ts
Here's a sample
I was able to play the first file at first, but then every time I tried playing any of the files, the computer bluescreened - both in Windows 7 and in XP. This was with Media Player Classic Homecinema v1.2.1161.0 and it's DXVA decoder.
http://www.sendspace.com/file/n6jqv4 plays smoothly in WMP11, resolution 1280x720 at 28% CPU load, with CyberLink H.264 video codec and ffdshow audio codec.
The only apparent problem is a strip of color below the picture.
Media info:
Graph studio:
Media info:
General
Complete name : C:\Documents and Settings\Stavi\Local Settings\Temp\WithoutaTrace-Exposure-1960250-1.ts
Format : MPEG-TS
File size : 34.6 MiB
Duration : 36s 169ms
Overall bit rate : 8 031 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Bit rate : 7 344 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.118
Stream size : 31.7 MiB (91%)
Audio
Menu ID : 1 (0x1)
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Duration : 36s 160ms
Bit rate mode : Constant
Bit rate : 129 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : -100ms
Stream size : 569 KiB (2%)
Filters
1. C:\Documents and Settings\Stavi\Local Settings\Temp\WithoutaTrace-Exposure-1960250-1.ts
2. CyberLink H.264/AVC Decoder
3. ffdshow Audio Decoder
4. Video Renderer
5. Default DirectSound Device
Connections
1. [C:\Documents and Settings\Stavi\Local Settings\Temp\WithoutaTrace-Exposure-1960250-1.ts]/(Video) -> [CyberLink H.264/AVC Decoder]/(Video In)
2. [C:\Documents and Settings\Stavi\Local Settings\Temp\WithoutaTrace-Exposure-1960250-1.ts]/(Audio) -> [ffdshow Audio Decoder]/(In)
3. [CyberLink H.264/AVC Decoder]/(Video Out) -> [Video Renderer]/(VMR Input0)
4. [ffdshow Audio Decoder]/(Out) -> [Default DirectSound Device]/(Audio Input pin (rendered))
Wow, you're all awesome. Thanks for the info.
