I got a FitPC2i from the first batch (which includes that SATA bug) and happened to stumble upon a weird bug: My FitPC crashed somehow (I use it as a mailserver and stuff, running 24/7), and after restarting it, it failed to boot up into standard init level (Ubuntu Linux 10.04). When investigating I found the hardware clock was set back to a 2010 date, and the system considered the filesystem to be corrupt because timestamps were from 2012, of course.
OK, I ordered a filecheck and corrected the date, but after deconnecting the device from electricity for transport reasons, the machine failed to boot up again - same problem, after checking filesystems the maching was set back into 2010 again
According to manual there should be a rechargeable battery on the mainboard which holds the date for at least 100 days. But the device had sufficient current till the day before the crash.
Installing an NTP server or a cron job won't help as file system check is performed before starting these daemons.
Any hints how to solve this problem anyone?
