I can only use Fit-PC2 with one monitor
hmooers
Post by hmooers »
Hello, I have a Fit-PC2 running windows 7 SP1. I have used the computer with several monitors but now it will only work with one monitor, an Acer v223w. With this monitor all is fine. If I shut down the computer and connect a different monitor with with VGA or DVI nothing comes up. I have tried older VGA only monitors and newVGA/DVI monitors and no other displays work.
On the monitors that do not work the screen background is black and I CAN see the mouse cursor arrow. However, there is no response from the mouse with either left or right click.
If you have seen this behavior or have a suggestion I would be very happy.
HM
Re: I can only use Fit-PC2 with one monitor
Please try to boot in to the safe mode and check if you are able to use those monitors. If this is a driver issue, there is an alternative video driver to try
