Problem booting from SD-Card
zsolt
Post by zsolt »
I now it's been asked several times. But I have problems booting from a SD-card.
Fit-PC is the revision which should work 1.6 GHz model. BIOS should be new enough. The SD-card is even showing up in the BIOS options.
I've tried several boot-loaders GRUB-legacy, GRUB2, syslinux, but with no success. Partition is msdos style.
Are there some requirements to the SD card to be bootable? I have a "full size" 2GB mini-SD card.
Btw. it boots fine from an SSD-HD.
Re: Problem booting from SD-Card
Can you please post a print screen of the output?
zsolt
Post by zsolt »
It just says: No operating system found
Can you please try to boot from this sdcard on other machine?
