cleaning and disinfection
jerry
Post by jerry »
I have a client who is installing several dozen PC2's in a hospital setting. They are asking about cleaning and disinfection of the PC. Does anyone have experience with that?
Re: cleaning and disinfection
You can unpower the FitPC2 and to heat it up to 85C. Please remove the HDD prior the process to avoid damage that the heat will cause to the HDD.
jerry
Post by jerry »
Thanks Gabriel. What about the use of liquid disinfectants/cleaners. Other than the obvious 'disconnect from power supply' and 'avoid liquids in the openings', do you have suggestions or recommendations? Bleach? Isopropyl alcohol?
We haven't tested the FitPC2 with those liquids, and for now we don't have an experience with disinfection.
