Is it possible to use 15 voltage for the fit-pc2i??
Posted: Thu Aug 18, 2011 4:17 pm
by MRTRACKER
Now in my lab, there is a 15 voltage battery, I am wondering if it's possible to use this.
If anyone has tried and the minipc wasn't burned :D , please reply. Thanks.
Re: Is it possible to use 15 voltage for the fit-pc2i??
Posted: Fri Aug 19, 2011 12:23 pm
15V should be fine, slightly higher voltage and capacitors will start to break down.
Posted: Fri Sep 02, 2011 12:01 pm
by Paul T
Hi
I want to run the fit-pc2 from a 15V power supply (not a battery). You indicate that 15V is OK but near the limit - can you let me know how much room I have so I can specify the power supply. Do the capacitors break down at 15.1V, 16V or 24V? I'm a bit nervous about running from 15V without this tolerance - or do you recommend running from 12V if at all possible?
Posted: Sun Sep 04, 2011 9:32 am
The capacitors tend to break down at 16-17V.
It is recommended to run at the nominal input voltage of 12V if possible.
Posted: Mon Dec 19, 2011 6:09 pm
by TurboSnail
Tip from crazy Swedish inventor:
To make my stationary 22" 12.0V screen :lol: usable in my car, without killing any capacitors I used normal 3Amper diodes. 8-)
The voltage drop is around 0.6V per diode, so in my case 2 diodes needed, to get
Voltage within 10% of that specified, i number i was comfortable with, in that case.
(Only using screen with engine turned off! More complex protection components would otherwise be needed.)
So if you are close to maximum voltage, add a few diodes and you will be fine ;)
>>>_@/"
(TurboSnailSmily)
