graphic just died
lucian
graphic just died
Post by lucian »
hi,
after a couple of days graphic just died. booting just fine, showing some flickering pixel in bios boot screen, it shows a lot of scrambled pixels. lines and colors after boot in the high resolution screen (1200x900). happens with boot from stick or harddrive.
a second fit-pc2 just behaves fine, so its not the monitor.
had installed ubuntu 9.04 with graphics drivers, harddrive is 500gb wd scorpio.
i guess the graphic chip messed up. can it be it got to hot? harddrive hat ~50° and cpu core 60 .. 70°.
i guess i can not fix myself, so i going to send back by amazon.
regards
Re: graphic just died
Sounds like a HW problem. You can get the unit replaced using rma@fit-pc.com
