Fit PC2 cuts out after a few seconds
greanie
Post by greanie »
My fit pc2, running XP, just cuts out after 10 - 20 seconds. Sometimes, the XP prompt makes it up, other times not. I have tried it with multiple power supplies, including a regulated bench top supply set to 12V (no current spike noticed). Nothing peculiar happened to the unit before this started doing this. I just took it out of the cabinet to plug it in and it started cutting out. Has anyone else experienced this? Is the unit cooked?
Thanks!
Re: Fit PC2 cuts out after a few seconds
To eliminate the software factor of the issue, can you please try to boot it with some Live OS like Ubuntu?
Return to “Power and Heat”
