FitPC 2 does not power on after left on to drain battery
jcalvert
Post by jcalvert »
I left my FitPC turned on to see how long it would last on a given battery. Now it won't turned on, even using the AC adapter.
Please help! Did I destroy my FitPC with this very moderate load test?!
Re: FitPC 2 does not power on after left on to drain battery
Hard to say if fit-PC was damaged.
You may RMA it and we will check.
Return to “Power and Heat”
