UPS power solution with graceful shutdown
Power discussions, CPU and case temperature
jardar
Post by jardar »
I was wondering if somebody had made an UPS power solution that could take down the Fit-PC2 gracefully and make sure it is powered again as soon as the power is back on so that the risk of OS/DISK failure due sudden power loss can be avoided?
The UPS would only need to be able to hold enough power to shot down the system gracefully and do need to keep it alive for any extent of time.
tjbaudio
Re: UPS power solution with graceful shutdown
Post by tjbaudio »
APC and I would assume others offer an interface where the UPS tells the computer to shut down. I have used that with Linux. I think Fedora has it already installed.
Return to “Power and Heat”
