Hard disk question
Posted: Sun Mar 29, 2009 3:38 pm
by Leech
I'm looking at buying the diskless PC2 version, and I would want a Western Digital Scorpio Blue WD5000BEVT 500GB disk in it. With this larger disk volumes also comes a higher operating temperature. Would the cooling of the Fit-PC2 be sufficient to allow this disk to be installed?
Re: Hard disk question
Posted: Sun Mar 29, 2009 4:26 pm
There is no direct correlation between HDD volume and its power consumption. There is correlation between RPM and power consumption. For a 5400RPM HDD you have in normal operation conditions (room temperature, not under HDD stress test) about 10-15deg margin between disk actual temperature (40-45deg) and disk max temperature rating (55-60deg).
