Current limit on SATA interface
Peter_Karlsen
Post by Peter_Karlsen »
Hi
In the SATA interface connector on the fitPc2i (p30 and p31), there is +5V on one of the pins. (On the PCB it is labeled +V5S)
How much current can I pull from this pin without causing damage to the fitPC?
Is this power supply connected to other peripherals?
Regards,
Peter Karlsen
Re: Current limit on SATA interface
If you are using FitPC2 without a HDD, then you can use up to 500mA
Return to “Storage”
