Hello guys the sd card slot fit pc 2 is too small. why is that the sd card does not fit into the fit pc 2 slot? I try to keep forcing it.
I also bought a SSD 30gb sata II 2.5", but realised that not many computers take it as it is quite new technology, so therefore will I not get all the speed out if it? What do you think I should do, get a new hard drive that's slower but with more space for the same price or keep this one?
Thank you guys
Just some questions
Re: Just some questions
Post by yogev_ezra »
The slot is miniSD, not a standard SD. Check whether your card is miniSD.
SSD will offer better performance but no dramatically, because the controller in FitPC2 is IDE and the SATA connector is implemented via IDE-to-SATA bridge. It's up to you whether to keep the regular disk or upgrade to SSD.
