Booting from the mini-SD slot
Posted: Thu Dec 10, 2009 12:21 am
by zendack
Will the device boot and operate from the Mini-SD slot without a hard drive? The application I am looking to use need enough space for the Windows OS and a small application. Everything else is Web Based.
Re: Booting from the mini-SD slot
Posted: Thu Dec 10, 2009 12:56 pm
by yogev_ezra
Not right now. Boot from SD is not supported with current BIOS. If in the future BIOS is changed to add this support, then it would be possible.
Posted: Tue Dec 22, 2009 12:30 pm
by S.I.E
Dear Yogev,
is this updated or still not possible??
Pls reply - thanks!
Posted: Tue Dec 22, 2009 12:37 pm
by yogev_ezra
Unfortunately it is still not possible today.
Posted: Wed Feb 17, 2010 8:18 am
by swilhelm
Any progress on booting from mini-SD?
Posted: Wed Feb 17, 2010 9:38 am
There is no plan to support boot from SD in the near future.
Posted: Thu Mar 11, 2010 5:50 pm
by monnier
irads wrote:There is no plan to support boot from SD in the near future.
That's really too bad. Alternatively, is it possible to access the PATA interface to use an internal CompactFlash drive? [IIUC, the chipset only provides PATA so the fit-PC2 uses a PATA-to-SATA bridge on top]
Posted: Thu Mar 11, 2010 5:54 pm
by monnier
Actually a great way to address this problem would be to get "coreboot" (formerly LinuxBIOS) working on those boxes.
Posted: Thu Mar 11, 2010 10:32 pm
by per
You can also boot from a USB memory stick, but perhaps it is not big enough for what you need.
