ssd performance?
yogev_ezra
Re: ssd performance?
Post by yogev_ezra »
Do you mind to perform some testing under Windows?
For Windows there are a lot of utilities like CrystalDiskMark, HDTach, etc. that should give us some more information.
siliconlunch
Post by siliconlunch »
OK, I am game, but I don't really have any Windoze licences. Which version of Windoze do you recommend, anyway?
yogev_ezra
You can try Windows XP Home, but it does not really matter which one.
siliconlunch
OK, got some XP. I will try and set it up and benchmark it.
Have you actually benchmarked any SSD's, just for reference?
yogev_ezra
Yes, this is why I suggested you to do it too: http://www.fit-pc2.com/forum/viewtopic. ... 1&start=10
I got anything between 70 MB/s and 90 MB/s, depending on the SSD used.
siliconlunch
FWIW, I replaced the SSD with a regular 2.5" 120GB HDD (Seagate ST9120823ASG 7200.2), and retested under Ubuntu.
Got the exact same results as I did with the SSD: about 60MB/sec max (seq. read). This is same result as noted in this post with the CompuLab stock 2.5" 160GB SATA HDD.
Strange that I did not see any performance improvement between the SSD and HDD. As mentioned, the same SSD in other machines can do almost 200MB/sec. In summary, I was not able to reproduce your 90MB/sec SSD read spec under Linux.
You tested using CrystalDiskMark / Windows. Could the bottleneck be a driver/OS issue?
yogev_ezra
Indeed it could be a driver/OS issue. This is why I still suggest you try it with Windows.
dadaniel
Post by dadaniel »
you will never get anything above 90-100MB/s, because limitation of the chipset
Return to “Storage”
