fit-PC2 2GB/2GHz Diskless: SSD drive for PCI express slot
serge230
Re: fit-PC2 2GB/2GHz Diskless: SSD drive for PCI express slo
Post by serge230 »
mbirger wrote:OK, sorry for the confusion.
Anyway, fit-PC2 in contrary to fit-PC2i indeed supports PCIe 1.0 single lane to mini PCIe slot.
Two important notes:
1. In your configuration this slot populated with WiFi module.
2. If you want to remove it, you will lose warranty as this slot located on the bottom (CPU side). So its removal removes the thermal coupling as well.
O.K. Thank you, I got it.
Return to “Storage”
