Ubuntu 9.04 supported
Re: Ubuntu 9.04 supported
When will recovery image be available?
We are not going to create recovery image for Ubuntu 9.04. You can reinstall using our wiki guide.Anthony wrote:When will recovery image be available?
After following the instructions for loading Ubuntu 9.04 from the wiki, I am recieving the following errors while trying to restart the xserver after installing everything.
Thanks for any help you can provide.
root@:~# startx
hostname: Unknown server error
xauth: (stdin):1: bad display name ":0" in "add" command
xauth: creating new authority file /root/.Xauthority
xauth: (argv):1: bad display name ":0" in "list" command
X: warning; process set to priority -1 instead of requested priority 0
X.Org X Server 1.6.0
Release Date: 2009-2-25
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-23-server i686 Ubuntu
Current Operating System: Linux 2.6.30.1-concerto-fw2.3-r1 #4 SMP PREEMPT Mon Jul 13 19:24:16 EDT 2009 i686
Build Date: 09 April 2009 02:10:02AM
xorg-server 2:1.6.0-0ubuntu14 (buildd@rothera.buildd)
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 12 19:55:28 2009
(==) Using config file: "/etc/X11/xorg.conf"
(EE) PSB(0): the stolenBase is:0x3f800000
(EE) PSB(0): screnIndex is:0;fbPhys is:0x3f800000; fbsize is:0x007bf000
FATAL: Module psb not found.
(EE) [drm] drmOpen failed.
(EE) PSB(0): [dri] DRIScreenInit failed. Disabling DRI.
(EE) [drm] Could not uninstall irq handler.
(EE) PSB(0): This driver currently needs DRM to operate.
Fatal server error:
AddScreen/ScreenInit failed for driver 0
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
ddxSigGiveUp: Closing log
root@:~# startx
Fatal server error:
for help.
As I see from your logs:
This is definitely not our kernel mentioned in wiki. If you intend to use custom kernel - you need to install drm module for Poulsbo chipset. Sources can be found at /drivers/gpu/drm in our kernel tree.Current Operating System: Linux 2.6.30.1-concerto-fw2.3-r1
Hello Denis,
I was on a lengthy working trip, so here is a late answer:
yes, both option are set in the way you describe them. Unfortunately my screen goes black once the X11 server should start (i see the loading bar with the ubuntu logo).
Here is my xorg.conf:
I tried to add the xorg.0.log, too but it is too long and i cant append it as attachment, so here is the grep EE from it:
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "glx"
Load "record"
Load "extmod"
Load "dbe"
Load "dri"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "ShadowFB" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "ExaMem" # <i>
#Option "ExaScratch" # <i>
Option "IgnoreACPI" "true"
Option "NoPanel" "true"
#Option "LidTimer" # [<bool>]
#Option "NoFitting" # [<bool>]
#Option "DownScale" # [<bool>]
Identifier "Card0"
Driver "psb"
VendorName "Intel Corporation"
BoardName "System Controller Hub (SCH Poulsbo) Graphics Controller"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
(II) Loading extension MIT-SCREEN-SAVER
(EE) PSB(0): has_fbdev is true
