Remove auto-on ?
gman
Remove auto-on ?
Post by gman »
I was wondering if it is possible to remove instant on a unit with instant-on and if it possible is it hard do do that ?
This is because i don't know if i want it or not. it would be nice if its possible to disable and enable it even if you need to open the fit2-pc to do that (switch/strap) ?
Re: Remove auto-on ?
Instant-on is hardwired and cannot be removed.
sdevans2
Post by sdevans2 »
With the instant on do you have the option to use the regular power cord and the option to wire to the 12 volt battery?
Yes. Instant-on has no effect on the 12V power rail.
davophoto1
Post by davophoto1 »
Is there something I can solder to remove the auto-on hard wiring?
yogev_ezra
Post by yogev_ezra »
You can add a power switch into 12V cable, and control the power using that switch. Other option is Fit-PC2 version 1.21 which has non auto-on version.
Return to “Auto-ON”
