Hi.
Please send me the file c:\Watchdog\instlog.txt
Windows 7 and Watchdog timer
Re: Windows 7 and Watchdog timer
Leonid Firdman
Here's the contents of instlog.txt:
watchdog.exe OK
watchdogCMD.exe OK
readme.txt OK
test.bat OK
freeze.exe OK
Ntport.dll OK
sc.exe OK
pathman.exe OK
zntport.sys OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport ImagePath OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport DisplayName OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Type OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Start OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport ErrorControl OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Enabled OK
HKLM\SYSTEM\CurrentControlSet\Services\zntport Time OK
watchdog service OK
pathnam command OK
watchdog.exe OK
watchdogCMD.exe OK
readme.txt OK
test.bat OK
freeze.exe OK
Ntport.dll OK
sc.exe OK
pathman.exe OK
zntport.sys OK
watchdog service OK
pathnam command OK
BTW, the XP watchdog driver and watchdog.exe seem to work in Windows 7 however if the watchdog timer is reset more than once quickly (under 2 seconds) the PC powers off and stays off. My Fit-PC2's are first generation with auto-on. I have multiple units and they all exhibit this same behavior.
Hi.
I need some clarifications:
1. What OS do you use?
2. What version of Watchdog do you use?
You can check it by typing 'watchdogcmd help' in command prompt
Leonid Firdman
Windows 7 Professional, and the latest version of the watchdog timer 2.1 which is downloadable in this thread.
IS Watchdog Timer 2.1 posted in this thread still the latest for FitPC2 running Win7 Pro 32-bit?
FitPC does not post this driver online under Software Rep for FitPC2.
However the IntensePC watchdog timer is posted for Win 7 Pro 32-bit.
Intense-PC_Win7_Watchdog_2013.06.19.zip
I installed this driver on the FitPC2 and it does not work?
Watchdog is timing out and resetting PC everytime with cmd enabled.
Help please, thanks!
